- Nov 14, 2006
- Warsaw/Poland
I know what the boards are, and I know that what's the better pick is often dictated by the relative price. Deals and opportunities change faster than I type this.
Focus on stability and electrical protection, as well as good cooling. DDR4 only, mobo shouldn't fuss about the sticks. M.2 needs to be real 4-lane PCI-E, 2 slots would be welcome but not a must-have. USB 3.1 preferred. Both SLI and CF preferred. Bad rep is an absolute bar because I can't afford periods of instability or WTF-suprises from BIOS updates introducing new incompatibilities when I have an urgent deadline on a client project.
What I am considering:
Asus:
Z170-P (either NIB or used is available)
Z170-K used
Gigabyte:
Z170 Gaming K3
Z170 HD3P used (about $25 cheaper than most here)
GA-Z170X-GAMING 3 Z170X
Z170 XP-SLI
MSI:
Z170 Tomahawk
Z170-A used (about $25 cheaper than most here)
Z170 Gaming M3 used
Z170-A pro (not a fave)
PC Mate (not a fave)
Krait (not the cheapest of all, perhaps a bit more expensive)
Asrock:
Z170 Pro4S used (about $25 cheaper than most here)
Z170A-X1/3.1 used
FATAL1TY Z170 GAMING K4
FATAL1TY Z170 GAMING K6 (not the cheapest of all)
EXTREME 6+ (a bit more expensive)
Biostar:
GAMING Z170X Ver. 5.x (a bit more expensive)
Difference from the cheapest to the most expensive is within 25%, less after removing outliers.
Need a clear favourite but would also appreciate knowing which ones are best avoided e.g. due to high rate of DoA/poor RMA handling. I'm not on current terms with that, as I don't work in the industry or have many friends who are enthusiasts, so there's only so little information (basically what I pick up here or stumble on by accident when reading tests, reviews etc.).
HALP?
EDIT: Inclined to rule out ASUS due to BIOS issues and Asrock due to larger GPUs blocking M.2. Out of MSI, probably skipping Krait and Mate. Not sure about M.2 blockage, but in any case the location of M.2 always seems to be less than ideal — as in somewhere hot and less than accessible. Above the GPU is more accessible but hotter and more difficult to cool with heatsinks and fans. Below GPU is less accessible but will at least benefit from GPU cooling if mounted in parallel to mobo. There doesn't seem to be any mobo with M.2 moved to the edge or mounted perpendicularly or something else that could help. :/
Asus:
Z170-K used
Gigabyte:
Z170 Gaming K3
Z170 XP-SLI
MSI:
Z170 Tomahawk
Z170 Gaming M3 used
Asrock:
Z170A-X1/3.1 used
Biostar:
HALP?
