I just picked up a used ASUS Rampage 3 Formula and am trying to install it but the screws that hold the CPU holder to the board are loose and I cant tighten them. Am I missing some nylon washers? did the previous user have some sort of L/C bracket on that needed longer screws?
I googled some images and it appears the original holder is gone. I took one off one of my toasted P6X boards and it fits but the top portion is still floating around, it is not like this on the P6 boards.
After installing the cpu hold down from my P6x board I decided to install the CPU and it appears to be tight in the socket. I hooked everything else up and powered the machine on and it powers up but will not post. Any ideas?
To give you some history on what I have, my friend had a P6x58D premium board that burned out when his power supply went down. He gave me his video card, 12gigs of corsair RAM, EVGA GTS 250 video card and an intel i7 CPU. Currently have a Silverstone ST75F power supply in my case powering all of this. The CPU, RAM and video card were untested when I got them.
thanks
thanks
