- Nov 2, 2008
- Thread Starter
- #21
To avoid further consufing myself...
My Current Setup is:
Asus Rampage Formula
Asus sound card (soundblaster soon)
Q6600 G0 (Vid: 1.3250v)
Zalman 9700 Cpu Fan
GSkill 4x2gb (8gb) DDR2 1066 (PC2 8500)
Western Digital 500gb HD (1)
Vistiontek HD4850 (crossfire soon)
Hauppauge! Wintv-hvr 1800
Lite on DVD burner
Sony BluRay Player
Antec TruePower Quattro 850w
Cooler Master Cosmos 1000 case
Windows Vista Ultimate 64bit
I have been getting confusing recommendations based on settings options I either don't have or vise versa. So to help me I want to post my bios options and from there hopefully you can better help me.
My Bios settings are:
"Extreme Tweaker"
CPU Level Up ---------------------Auto
Ai Overclock Tuner----------------Auto
CPU Ratio Setting-----------------Auto
FSB Strap to North Bridge---------Auto
Dram Frequency--------------------Auto
Dram Command Rate-----------------Auto
Dram CMD Skew on Channel A--------Auto
Dram CMD Skew on Channel B--------Auto
Dram CLK Skew on Channel A--------Auto
Dram CLK Skew on Channel B--------Auto
Dram Timing Control---------------Auto
1st Information : 5-5-5-15-3-52-6-3
2nd Information : 8-3-5-4-6-4-6
3rd Information : 14-5-1-6-6
Dram Static Read Control----------Auto
Ai Clock Twister------------------Auto
Ai Transaction booster------------Auto
C/P : A1 A2 | B1 B2
LVL : 04 05 | 04 05
CPU LED Selection---[CPU Voltage]
NB LED Selection-[North Bridge Voltage]
SB LED Selection-[South Bridge voltage]
Voltiminder LED---------------[Enabled]
CPU Spread Spectrum---------------Auto
PCIE Spread Spectrum--------------Auto
(next screen)
"Advanced"
"Configure advanced CPU Settings"
C1E Support-------------------Disabled
CPU TM Function-------------------Auto
Vanderpool Technology----------Enabled
Execute Disable Bit------------Enabled
Max CPUID Value Limit---------Disabled
Intel Speedstep Tech-----------Enabled
Under stock settings I ran memtest for about 12 hours and found no errors. Also, under stock settings I ran Prime95 for 2 full passes and system passed it fine.
Thanks again for your help
Zalman 9700 Cpu Fan
Lite on DVD burner
Sony BluRay Player
"Extreme Tweaker"
C/P : A1 A2 | B1 B2
LVL : 04 05 | 04 05
(next screen)
"Advanced"
