Status:Almost Stable
Just finished extended testing with the advised settings from you all. My system is almost stable. Here are my testing results, i have made screenshots of HWMonitor, CPU-Z and tested with Prime95 (check start time and my time in icon tray). The temp monitor in HWMonitor are the CPU temp numbers, not in AMD FX-9370 Temp pack)
Main settings:
Mode: DOCP (DRam OC Profile: 1600MHz, CPU Ratio: 22, CPU/NB Frequency 2400-MHz, HT Link Speed Frequency: 2400MHz.
Mode: CPU & NB Voltage: Manual mode, CPU/NB 1.25
The rest is default settings, here are my results:
1.30V - CPU MANUAL Voltage (after windows logo FREEZE)
1.31V - CPU MANUAL Voltage (after windows logo FREEZE)
1.32V - Voltage (At Welcome text FREEZE)
1.33V - Voltage (At Welcome text FREEZE)
1.34V - Voltage (Prime started after 8 min FREEZE, degrees 55)
1.35V - Voltage (Prime started after 4 min FREEZE, degrees 57)
1.36V - Voltage (after windows logo FREEZE)
1.37V - Voltage (Prime started after 4 min FREEZE, degrees 55)
1.38V - Voltage (Prime started after 5 min FREEZE, degrees 59)
1.39V - Voltage (after windows logo FREEZE)
1.40V - Voltage (Prime OK, just FREEZE at Game)
1.41V - Voltage (Prime started after 4 min FREEZE, degrees 64)
1.42V - Voltage (Prime started after 4 min FREEZE, degrees 65)
1.43V - Voltage (Prime OK)
1.44V - Voltage (after windows logo FREEZE)
1.45V - Voltage (Prime freeze at 68 degrees, and input text becomes yellow in bios), 1.45 above freezes constantly.
The most stable settings were 1.40 and 1.43 volt.
I started with changing the settings with 1.43Volt and my system is almost stable, i doesn't freeze at prime. didn't freeze at game. I will post results later. The most stable settings at the moment are:
DOCP:
Dram OC Profile: DDR3-2400MHz
CPU Ratio: 22
Memory Frequency: DDR3-2400MHz
CPU/NB Frequency: 2400Mhz
HT Link Speed: 2400MHz
CPU Manual Voltage: 1.431250
CPU/NB Manual Voltage: 1.200000
All the rest in AI Tweaker AUTO, also DRAM Voltage (was advised 1.65 but auto looked better at testing). Digi+ Power CPU LLC: High, CPU/NB LLC High and CPU power Phase control: Optimized.
I have included the testing and most stable result as screenshots in attachment. The Max temperature with above setting (Prime test) was 73 degrees (BE Quite! Dark Pro 3 cooling, casing closed. So far no freeze. If you have other advice please let me know, i think i am not finished yet, but very close.
My aim is NOT overclocking or high speed, just want a stable system with freezing or crashing. I come from Intel so this is a big surprise ;-)
Thank you for the help till now. Greetings
