n00neimp0rtant
- Jul 31, 2014
Hello, I'm brand new here. I just finished my first DIY PC build, and found this forum while looking for support. Seems like a friendly and helpful place to get advice and chat about PC stuff.
My first build is using an ASUS Z87 GRYPHON mobo; every part (including the mobo) is completely new, sealed in box. When I finally got everything put together, I plugged it in, turned on the PSU, and 2 lights lit up on the mobo: a big, round, green one that stayed on solid, and small green one labeled "FLBK_LED" that blinked on and off about every second or so. When I press the power button on the case, absolutely nothing happens; no fans, no additional lights...nothing.
Looking for support, I found a number of a terrifying suggestions: PSU could be bad, mobo could be bad, or something could be shorting out the mobo. I did see a few people with the same issue saying that their machines would turn on if the power button is held while the PSU is switched on. I tried that, and wouldn't you know it—it turned on. It then shut off after about 5 seconds. So I tried it again, and it stayed on this time. Moved the machine over to my monitor, plugged it in, tried again, and it turned off after 5 seconds. I've tried this about 20 times now, with a solid 50% success rate. Half the time, it just turns off after 5 seconds; the other half, it stays on.
And it's a good "on" too. I was able to get into the BIOS, configure my boot devices, and even fully install a copy of Windows 8 on the machine. And once it's on and booted up, I'm not experiencing any sudden shut offs or anything rogue like that. But the issues have not gone away. If I turn on the PSU without holding down the power button, I still get the blinking FLBK_LED. And if I hold down the power button while turning on the PSU, I still have that ~50% chance that the machine will shut back off after 5 seconds.
Obligatory reminder that I'm completely new to this, but I have a hard time convincing myself that any of the parts could be bad. They are all brand new, and once the machine gets booted up, I have no problems at all. But I just can't fathom what could possibly be causing this issue. I'm aware that the FLBK_LED is only supposed to blink while the mobo is awaiting a BIOS flashback, but I can get into the BIOS if I interrupt a successful boot with the delete key, and everything in there seems to be in order. Just trying to fish for some suggestions on what might be wrong and how I might be able to fix it.
Thanks in advance.
Part list:
Thanks in advance.
Part list:
