Hello,
I have an AMD Athlon XP 2400 processor running on an MSI K7N2 m/b. I'm using AS5 thermal paste and a thermaltake volcano 7+ cpu fan. The pc also has a cheesy 92mm outtake fan. My idle cpu temps are around 45C and they peak at 62C when the cpu is loaded (in fact, that's only after 20 minutes of 100% cpu usage...I'm afraid to have the temps rise further).
I just ordered a 120mm case fan which I'll use for exhaust (it is rated at 79 cfm). I also bought a real psu (coolmax) with a fan underneath for better airflow. My current psu is delta (some no name brand).
Just to clarify, I'm not overclocking. The processor is running at 2.0 Ghz.
Will the exhaust fan and new psu bring my max load temps down below 50C? I know the hsf is outdated...perhaps a better one would help as well. I run the 7+ on medium because it's 48db on the max setting. I really can't spend more than $100 on cooling, and I've already spent $65 on the psu and 120mm fan.
Thanks!
-Eric
Thanks!
-Eric
