- Dec 7, 2003
- Portland, OR usa
Yeah. Whatever.
Sarcasim is not really needed here. However it was nice that you deleted you prior post in which you also stated;TheWesson said:Yeah. Whatever.
YviE said:- try to rewire your case (don't get me wrong it's not bad, but could improve airflow a bit and won't cost ya a thing)
philippmike said:I was simply echoing the past experiences I have had in fan placement and ducting. I also have read on different sites/forums that a system with nothing but exaust fans cools the best unless you tune your exaust/intake ratio properly. I have found the best way to do that is to use ducts.
eric1787 said:As someone pointed out, my processor is really cheap.....why spend loads of time and money on cooling?
eric1787 said:Phillipmike, that looks great...but I'm not overclocking and I dont want to make this cooling issue into a big thing. As someone pointed out, my processor is really cheap.....why spend loads of time and money on cooling? I just need a simple solution. He just has this plastic duct with an 80mm fan in it...it is angled over the cpu hsf.
TheWesson said:what I'm going to do with our new dual 3.6 is turn the front intake to exhaust (and clear the front intake as necessary), then it'll have 3 exhaust fans: rear 120 mm, front 92mm, and power supply.
Then a large oval hole above the two CPUs in the side will be a passive intake.
Hopefully this will keep the fans on the 3.6's HS's from screaming like banshees.
I too believe that you may as well have all fans to exhaust, and a passive intake, so long as the passive intake is large and free, and the airway from intake to exhaust is not too obstructive.
DuckDodgers said:That's an interesting concept. Exhaust out the front and the back with passive intake above. It sounds like a good idea. It sounds like you could almost create two vortexes inside your case.
Why did you choose to intake from the top rather the bottom? Warm air rises, wouldn't you be drawing cool air through the warm air and back through your case? Just a thought.
