Damn, had a good deal today for 3 GB of RAM, Athlon 64 3000+ and mobo, bid too cheap, another guy took it for $105.
Alrighty then! One final question.
Mobo spec say that maximum 3 GB memory is supported. Mobo has 4 DIMM slots, and each DIMM slot can take 1 GB stick. Do you think that thing will support 4 GB of memory?
Make sure you populate all four slots though... so 2x1Gb and 2x512Mb.
What a timely thread. I just cannibalized a hard drive and DVD drive out of my old machine. What was it you ask? An Athlon XP 2600 Barton. My setup would do 2.6ghz effortlessly, 2.7ghz with quite a bit of cooling and 2.8ghz with some stability issues. I was running it with a Shuttle Nforce2 board, an SI-97 heatsink with a 90MM Panalfo sitting atop it. It DOES run dual channel. I had 2 512s in mine running dual.
http://eu.shuttle.com/archive/en/an35n.htm
Was it this one ultra 400 model? I have one in my current file server
yep that's the board. Best board I've owned EVER
Ha, that AN35N ultra was the same board I had in my old system! It was a killer board! Overclocking was SO easy, the bios options were clearly labled, it looked cool, it had a 'game' port, so I could use my old gamepad with it, and that was a great chipset at the time.
