Have you tried any other games or benchmarking tools to see how those compare?
Run 3DMark06 and post your SM 2.0 & SM 3.0 scores, and also the clocks you do the run at.
8600GT gets around 200-300FPS in CSS
I just got a score of 11014 after overclocking. If your CPU's score is added to the final score, then you are about 3-4K over my score simply due to your processor's score. My processor only recieved a score of 2262 compared to your 4K+.
I overclocked from 700/900 to 800/950 and now my FPS at idle in Warhammer is 80, and my FPS in CSS at MINIMUM is 160, and maxes at 260 while in buildings. That's such a huge boost from what I'd consider a small overclock(I'm a new overclocker). Also, my GPU is running at 51C while running Warhammer Online and that's with the stock Sapphire fan/heatsink. I don't know why I was getting such horrible FPS with the stock speeds.
EDIT:
The screenshot of the temp didn't work, oh well. =P
Well, I just tested F.E.A.R on maximum settings (4x AA and 16x AF, etc) and got a maximum of 140FPS, a minimum of 45FPS and an average of around 80. How's that seem for this card?
1280x1040, no AA, AF Optimal
Here are my scores:
3DMark Score: 10548
SM 2.0 Score: 4502
SM 3.0 Score: 5599
CPU Score: 2183
My Sapphire ATI Radeon HD 4870 1GB is running at 700/900.
I'm not going to overclock my CPU unless I get a better heatsink/fan and thermal paste. Right now at idle I run at 40C, and that's not as low as I'd like.
How high have others gotten their 4870's? I've seen alot of people complaining on newegg that they can't see to get the core clock stable above 780mhz. I'm at 815/1000 right now and running fine with a temp of 55C and about 45C idle with fan speed at 22%. What temperature should my GPU stay below at full load?
I play Counter-Strike: Source competitively for over 3 years. It is very CPU intensive and only uses one core. A gpu can only put a minor difference to a game like that. However I got 100+ fps at all times running 4850 and a 2,83ghz cpu
