Can you get to the BIOS on boot? If so, jump in there and check temps. That will tell you if the heatsink is mounted right. Even a stock Intel will allow it to boot on stock and get to windows... unless it isn't mounted right.
630W................ what brand and model. All PSUs are certainly not created equal.
Create a signature (like trents!) so we know EXACTLY what hardware you are working with.
Sweet googlymoogly... Raidmax is traaaaaaaash. It's better used to start fires than power a pc...RaidMax 630
I just did mention an in expensive cooler that would likely fit. The specs say how tall of a cooler will fit it.
It's an old case...they didnt have that info in specs when it was released 1p+ years ago...but water cooling was around then. Just look at what fans it can take. I recall 2 140mm in front or top... I know it had an odd 200mm somewhere.
That said, I wouldnt reccomend an aio for his uses... doesnt seem to be a needed? Even a hyper 212 eco (assuming it fits - specs should say that...) will suit a 9700k. He can likely even overclock on it a bit too. Remember, it doesnt have HT and runs cooler than a 9900k.
I absolutely agree. I said that without a back story...Back in the day, I did own that case and dont recall if it was it or the next case where I first used water. If that was the case, I had a 2x120 Thermochill 120.2 rad up front with the hdd cage removed....Just because there's a fan spot for a 120 mm fan or two doesn't mean there is enough clearance to the periphery of the fan hole to allow a radiator to fit. Radiators tend to extend beyond the fan frame on the two ends of the radiator. I have some cases where a bare fan will fit but not a radiator that takes that same fan size.
