My point is that your set-up is very, very ill-suited for home use, and even in their correct environment, those parts are probably not very good performers. For that kind of money, you could get a much better performing system, that is actually made for use indoors.
you would be surprised how much better this set-up sounds compared to some of the multi 1,000$ I have set up for others and the power use from the wall is only 2 amps. I can all ways set it up where it is true 4.1 or 5.1 or whatever I would like. it's almost better then the same-ish set-up in my car. I also don't have Nabors to **** off. also in no way are they "not very good performers". i guess you would haft to hear it to under stand and whats the fun if you don't experiment and find out what works.
