FEATURED Ballistix Elite 4x16GB DDR4-3000 - BLE16G4D30AEEA
Woomack
Benching Team Leader
This is my first test with quad channel memory on the Intel X299 chipset. It's also first 64GB review on my list. Here is Ballistix 4x16GB DDR4-3000 memory kit. It contains four 16GB memory modules packed separately but you can buy exactly the same memory in one package as single modules have the same product numbers and used IC.
Couple of photos of the memory so we know what are we testing :)
There is only one XMP profile which is enough and works fine on my ASUS X299 TUF Mark 2 motherboard.
Stability test in AIDA64 is enough. It covers about 95-97% of RAM so there is still a chance to make a screenshot while it works ;)
There is no software which can read what memory IC is under the heatsinks and I'm not really going to remove the heatsinks but scalling and results on other 16GB modules suggest there are Samsung B chips ( also can see some through holes in the heatsinks :) ).
This is how my motherboard sees the memory:
Review has been published here.
Test results and overclocking
3000 15-16-16 1.35V ( XMP )
2133 15-15-15 1.20V ( Auto )
2666 13-13-13 1.35V
3000 13-13-13 1.35V
3200 14-14-14 1.35V
3466 15-15-15 1.35V
3600 16-16-16 1.35V
3600 13-13-13 1.57V
Can you add few words how it compares to 2x8GB tests at same timings?
I was curious about the loss in performance coming from 4 sticks instead of two. It would be nice to see some results comparable to the tests I see in your old thread. Also, is the performance different even if you achieve same settings? (let say both machines get to work with 3400 15-15-15, will the difference still be there in test results, or maybe the OC potential of the CPU drops due to bigger stress on IMC?
Regardless if I use 2 or 4 sticks and dual or single rank ( 8 or 16GB ), maximum frequency on this platform is the same so 3600 and timings are also the same. Performance is about the same, however 8GB modules have tighter timings. IMC is not an issue here. Maximum bandwidth is limited by cache speed.
3733 17-18-18 1.35V on new motherboard from Supermicro - C9X299-PG300
It also runs at 3600 16-16-16 1.35V
Can confirm that this memory works @3600-3733 16-16-16 1.35V on every X299 ASRock motherboard ... except X299E-ITX/ac which supports SODIMM ;) , ASUS X299 TUF2, mentioned Supermicro X299, ASUS APEX Z270/370 ( probably other ASUS ROG too but I had no chance to test or don't know anyone who tested it ) and also at 3200 16-16-16 1.25V or 3466 16-18-18 1.35V on ASRock X370 Gaming ITX/ac.
Will test it on the X399M Taichi in next days.
