- Feb 14, 2003
I have no case fans right now.
This is clearly your problem. Don't worry about the hsf. The problem is that the air that is coming in contact with the hsf is too hot to effectively cool it. Athlons are not made to run in cases without fans. Fans are basically required for their use.
Case fans are quite cheap really, you can get them for like $4-5 shipped on Newegg. If you don't install case fans, your only alternative is really going to be leaving the case open.
Don't forget temps are going up this time of year, so you're likely going to heat up more and more as the weather heats up, and have increasing instability.
