- Thread Starter
- #121
Deathknight said:Well I tried to skim over most of the thread here after shiyan PMed me. There was alot to read so forgive me if I say something that was already covered
If you have a multimeter available to test your PSU with that would probably give a final answer if your PSU is to blame. I didn't catch what motherboard you used to have, I just saw it was a kt400 chipset? Most older AMD motherboards used to pull cpu power off of the 5v rail. Some newer ones do as well but the NF7-S pulls power off of the 12v rail. Its possible that your PSU just doesn't have the juice on the 12v rail to handle the additional load of the cpu on there.
I also saw some talk of memory timings but I didn't see for sure what timings you were running at qbas? If you have not already tried to loosen your timings you definatly should, this could help diagnose if the memory is the problem. Also if you have not given more voltage to the memory you may want to. I am not familiar with that brand of memory but some brands of high speed memory work better with more voltage. If its just tested and rebadged pc2700 then it may need the additional voltage (some memory is actually only rated to run at the timings and speed they rate it at if you do run more voltage).
Anyways from what I read the PSU seems to be a prime suspect. The bios is not really an accurate measure of the true voltages, however the 12v rail seems to be off ALOT. I would suggest beg borrow or steal a multimeter to find out for sure or just suck it up and invest in a better PSU. Not sure what brands you have available to you over there but a quality brand that has some beef on the 12v rail will go a long ways
Thank you for your post . Well i have tried to use memory timings at the lowest possible and i have used memory voltage at 2.9 (well not tried now when i have put both power connectors on to the board).
Well we have the best option for PSU's: Antec
Oh and i was eyeing this PSU, tell me what you think about this PSU: http://www.nexustek.nl/nx4000.htm
Where could i get a multimeter? From a computerstore?
My old mobo was KT4 Ultra MS-6590 (MSI make). Well if the nForce2 takes power from 12v more it would definetly be my PSU that is causing the problems. But i try to put memory voltages to 2.9 and try again.
