- Feb 19, 2010
Not trying to burst your bubble but vendors aren't exactly friendly about doing an RMA with a CPU that has bent pins so don't be suprised if it's refused.
As said, those pins aren't bent badly at all and I've fixed pins like that many times before to the point it's almost routine. If it's refused, just use something like the tools suggested - I normally use a miniature flathead screwdriver.
I use it to both separate and realign the pins. I'll also add even after these have been fixed sometimes the CPU won't just fall into the socket, it's not uncommon for it to have a little resistance but never try to insert it by force. What I normally do when that happens is to note which part of the CPU is resisting - Usually the CPU by the way it rocks/trys to remain out of the socket will tell you the area where the bent pin is. If for some reason after examining the pins I can't find it, I'll then reinsert the CPU and apply just enough force and no more to make the offending pin(s) show when it starts to bend but always careful to stop right at the point when it starts bending.
Then of course I'll fix it too.
Might take more than one attempt at fixing them to make it work but it can be done.
If you use AMD's enough, you'll run into a bent pin sooner or later anyway.
Good luck!
Good luck!
