...ok...observe and report back.Haven't observed gpu tmp with the side panel off.
Try running msi afterburner and setting a fan profile, see if that helps.
You can run FL off of a AMD proc such as mine and it runs just fine. The only time you will see issues is with very CPU intensive VST's and polophony involving more than 10 notes at once. All of that being said I have 0 issues running FL on my rig other than the fact that I have yet to invest in a sound card and ASIO does not like running certain settings off the onboard sound on my M5A99FX.
Intel is a great choice and I think you will be very happy but if you have the money to blow go All intel
65C idle is high, and I don't think the reference coolers do shut the fan off.
I'm thinking you have an RMA situation.
