- Sep 24, 2006
- In your Computer
well the windows defrag is SLOW, defrags one HHD/patition at a time, uses alot of RAM & can't do the job well
Thanks, looks like a good read!Audioaficionado said:
WeezleXX89 said:you shouldn't run programs or any other activities while defragging.
redrumy3 said:i use o&o defrag with vista does fine, i just turn of the service that always runs and when i want to defrag i turn it back on no complaints works well with vista as well
start>run>services.msc and find the o&o service turn it off when u dont want to defrag and then turn it back on when u want to defrag
It won't screw up your PC or anything. The problem with running programs while defraging is that the running programs won't get defragmented. So it's a good idea to try to close as many programs before defraging (this includes the toolbar programs too)IAmMoen said:do you have any horror stories to back that up? (Actual genuine curiosity)
fullgrip said:Dudes, do any of these defragmenters allows us to REALY do something like this, in the exact order we tells it to:
Like In the begining of the drive:
- Windows folder
- Battlefield 2 folder
- Swap file
- Battlefield 2142 folder
- GRAW folder
Then, at the end of the drive:
- Movies folder
- Music folder
- e-books folder
