grumperfish said:Another vote for o&o- low system resource usage, simultaneous drive defragging (has to queue partitions though), and customizable defrag runs.
RJARRRPCGP said:I would watch out for O&O Defrag, too! I had a problem that I never did before. When I tested O&O Defrag V8 on Windows XP, when using the boot-time defragmenter, after it was done and I rebooted, gotten this NSOD:
Windows could not start because the following file is missing or corrupt:
C:\WINDOWS\SYSTEM32\CONFIG\SYSTEM
What was that all about? That was even when my PC's rock stable!
That error message means that my registry was F-ed!...
WeezleXX89 said:whats the big deal spending 30 bucks on a software called Diskeeper when you can defrag using WIndows XP tools? What are some good tools disk keeper uses?
WeezleXX89 said:I agree with you Archer36. how does windows defrag suck?
Just be careful with PerfectDisk and O&O Defrag. I dunno what the exact cause is.
Watch out, especially if you customized Windows XP or Windows 2000 with nLite.
This is bad news. because I never gotten HDD corruption with Diskeeper.
I never had any HDD corruption with PageDefrag and Contig.
They're more trusted than the big commercial ones.
One that I have been testing is JKDefrag, which is at the following web site:
http://www.kessels.com/JkDefrag/
JKDefrag, unlike all of the others is FOSS! Horray!
Also, I'm gonna test the Auslogics defrag software.
The Wicker Man said:Same thing happined to me, thats when I stopped using O&O. Ultimatedefrag has been working wonderfully on mine and kids PC......
Test Ultimate if you havent yet, I think you will be pleasently suprised....
The Wicker Man said:Anybody here try Ultimatedefrag????
I like the options for file placement, you can select what goes where, but every once in a while it hits a file, then I BSOD, this first happined on D: partition, when it hit an xbox ISO. I deleted the file, and it ran threw without issue, today I tried C:, and came home to fint it waiting at the log in screen.
Other then that, once I get it figured out, Ultimatedefrag will be my main defragger......
