- Aug 23, 2014
I use an intel 2 core e8400 3ghz with mechanical drive and 3 GB ram.
Will something like a FX-8350 with 8 GB ram and SSD be way faster even if not OC'd?
FX-8350s sell for like $100 used on ebay. I want used, no debate.
I need performance for Digital Audio workstation music production with software synthesizers, some gaming but nothing fancy I'll lower res or something if needed to not lag on new games. I need web browsing and windows explorer to be as lag free as possible.
I don't need intel's built in CPU's GPU. I have a 1GB radeon HD7700 GPU. Will I get better value with an AMD without integrated GPU?
I don't want to overclock if possible, but I don't think there's anything that allows me to spend less and get more performance by just Oc'ing it, so I guess I do need the CPU to be oc'able, but I don't want to buy a fancy heatsink, maybe just a slight upgrade from the stock one or whatever makes sense.
I want the CPU socket to fit a motherboard which has no wireless components but has usb3.0. And I'll be putting 8 GB ram into it.
can you recommend the CPU, mobo and 8GB RAM. All used I want. But price range for new would be about $100 for the RAM, $100 for the mobo, and $250 for the CPU, but I can probably find these used for $50 RAM, $50 mobo, and $100 CPU.
THANK YOU!!
THANK YOU!!
