- Aug 23, 2014
- Thread Starter
- #21
Ok, sorry, actually, those high-end laptop CPUs that bench right under or above the FX-8350 in the link are no where near $550 used like I said, they're like $1200 shipped used. I can easily find parts to build a used 8350 machine for half the cost and still get better performance, have a 24" 16:10 LED monitor, better GPU, better SSD, better ram, and don't have to sit 1 foot from the screen, etc.
Plus as you said, it will only be as good as what I need it for, and the most I'll push it for is probably multithreading in DAW which AMD is said to be better than intels (the laptops), so that's good, I just also want to make sure that for regular internet and windows explorer that I never have and lag issues ever again, but I don't think that would happen even with something like a stock 8350 mobo.
So I'll continue with this build which is only missing the mobo, FX-8350, heatsink, and RAM. I'll get the sabertooth and google what the best RAM is I can hopefully get for around $85 used. All I'm wondering is what heatsink that simply installs on the processor without water and pipes and radiators that will allow good OCing the 8350.
thanks so much, all.
