- Jun 6, 2002
NG has some black friday deals going on and im looking at these 3 kits, yea at different price points.
all of them are 8GBx2 kits.
https://www.newegg.com/g-skill-16gb-288-pin-ddr4-sdram/p/N82E16820232880
https://www.newegg.com/patriot-16gb-288-pin-ddr4-sdram/p/N82E16820225142
https://www.newegg.com/patriot-16gb-288-pin-ddr4-sdram/p/N82E16820225144
never used patriot before mostly G.skill in the past, if the steel series is as good now as it was in a few reviews i saw online it would be worth going with the 4400 kit. while i no longer really OC my rigs since the most demanding game i play is WarFrame if that gives you a idea. given the deal it seems on the 4400 kit and even if i cant run it at 4400, running slower speed with tighter timings should off set that a bit.
thanks for the input from a out of touch oc'er.
