already tried with fraps not running. already tried with no AA. already tried all your suggestions.
not sure why i should argue with you. you stated 30 fps is not a smooth frame rate and that i should tone down my settings, and that crysis can never run smooth at my graphical settings....if that's the case i would not have purchased these "high end" cards.
i am telling you and showing you, and you even acknowledged yourself, that these cards are exhibiting a stutter / hitch at frame rates which they should not be. if you chose to believe this is "normal" then there is nothing more i can do or will do to change your mind.
your cards are nowhere near to high end.
not even an SLI 480gtx can achieve 60fps in crysis at that res everything on max.
and btw, 30fps is not smooth, ppl still think that 24fps is enough to make an animation, that is for images of moving targets.
to get something smooth on the monitor, which are subsequent images of Static targets, you need over 50fps to not notice anything.
this said i'll tell you what everybody else told you already.
the gtx460 is a new architecture, different from the gtx465 - 470 - 480.
so the drivers we currently have are not really . . . polished.
i was getting under 30fps in BFC2 when i first got my gtx480, after driver release no stuttering and no lag anymore.
i suggest you stay calm and be patient.
and welcome to the world of "release before it's ready"
you'll notice many companies following this philosophy
