- Sep 27, 2010
Do you recommend I update the bios with F12 during post?
I flashed to it with F12 during post, had no problems doing so. But flash at your own risk.
Im still playing with it so I can't tell you what improvements there are if any.
You might even be able to go higher than 240 MHz - at least it can't hurt to try.
Edit
Don't give up on the RAM just yet. Concentrate on the CPU and cpuNB first, then you can drop back and see what can be done about the RAM speeds. There are still some tricks there that can be explored ...
Another strange thing I've noticed is when its idling the CPU multiplier drops to 4, the core voltage drops to 0.97 but when it comes back under load the core voltage only goes back up too 1.32 (stock) and not the 1.42 that I've set in the bios
Can you post a shot of your CPU-Z SPD and Memory tab ...?
Your system is downclocking itself when it is not needing to run at full you can disable it in bios if you want it to run at full speed all the time.
I've also seen some strange temps in HWMonitor, my cpu temp is always several degrees higher then my core temps and its showing my mainboard temp around 60C maxing at 71C
Can you tell me where in the bios it is?
What type of cooler do you have on the cpu?.
Disable C1E, It's under the Advanced tab then CPU configuration in bios.
I want to do this as the issue isn't with it downclocking but that the Vcore doesn't come back up too the overvolt that I set in the bios
Anytime you make the change in the bios you cannot figure it when adding the numbers to get a total for some reason it does not work this way with this motherboard, you will need to make a change then reboot and go back into the bios and check what the readings are under the health section to get a true reading of the voltage and temps.
If you notice under core temp it is not giving you the true reading for the voltage to the cpu but cpu-z will show the actual voltage to the cpu. Some software will not read this bios correctly.
CoreTemp was never meant to show the running vCore, only the BIOS CPU VID. I'd guess this was to maintain it's small footprint ...If you notice under core temp it is not giving you the true reading for the voltage to the cpu but cpu-z will show the actual voltage to the cpu. Some software will not read this bios correctly.
Yeah, right now cpu-z is showing my Vcore at 1.32 but its 1.39 in the bios with overvolt at +0.05 also Toverclocker is showing the CPU-NB at 1.175 but it's 1.225 in the bios with a overvolt at +0.05
Thanks for pointing that out - I missed the post.I'm gonna log off now, but QuietIce if you have a chance to look at the shot of cpu-z I posted and give me some advice on my RAM I'd appreciate it.
Hmmm, it looks like you'll need to set 9-9-9-24 manually and make sure you're at a 2T Command Rate. Increase the RAM voltage to at least 1.70v. That's a start, so let's see if that works first.
