- Feb 21, 2008
- Baltimore, MD
is this possible? ive been doing a bit of reading but it seems i cant get a straight answer. i have mythbuntu 8.04 64-bit and im enjoying every minute of it. it works great as a "video jukebox" for my ripped DVD's (all 900 GB of them lol). but now that ive moved up to a 42" plasma i want to start to move to HD content. i dont have a Blu-Ray player, so i was thinking of getting a blu-ray drive so that i could just play them back.
from what ive been seeing, playing them back directly from the disc wont work yet. however using the dd command one is able to make an .iso file out of the entire disc. GREAT! id rather have it on my HDD anyway so that its easier to access from my couch (its too much work getting up and swapping discs )
now my question is, will mythtv be able to play back this .iso like my other dvd .iso's? obviously it will be a higher bitrate and a much larger file. and i stream over a network to my frontends, will i run into issues here? i have gigabit ethernet (router is gigabit as well).
what about HDCP? will i run into issues there too? or will the .iso no longer have HDCP limitations? i use a DVI-HDMI cable to transfer video to my tv from my frontend. video card in the frontend is a 7200GS, which as far as i know is not HDCP compliant. does linux even support HDCP even if your hardware does?
how about sound? ive read that they use some different sound formats on the BD discs. will i run into issues there?
i know ill have to update udf to 2.5, but other than that, what am i facing?
any help is much appreciated. thanks.
