- Apr 10, 2010
i7 7800x
Asus tuf x299 mark 2
2400 mhz ripsaw on dual channel
asus 1070 8gig
thermaltake Toughpower Grand RGB 650W Gold Fully Modular
windows 10 installed on ssd
Corsair Graphite 760T FullTower
Problem with pc
It sometimes, does not post (bios) nore boot into windows, monitors will be black, no lights to keyboard and mouse plug into usb 2.0
Sometimes it takes 10+ hold down power button then restart to boot, once bios boots, windows always comes next and pc works just fine.
If i restart pc i get more lucky with getting back into windows, if i do a shut down i get very unlucky and more so then not, its hard to get back into windows. I do eventually get back in, sometimes it might take 3 times or 5 times, sometimes it has taken 20 times.
Again, when im having this trouble I get 0 power to keyboard and mouse, and it will not even boot into bios. I hold down the power button to restart, once i do get into windows, pc works 100% fine.
Ipower said it can be a ssd issue, or motherboard issue...
Before i send this computer back what do you guys think? I really dont want to send it back unless if i have to put money into it, then of course i want to send it back.
I personally dont think its a ssd issue, because i cant even get into bios at times, no hdd/ssd i should be able to get into bios no matter what?
I also dont think its a gpu issue, because again im getting no power to keyboard/mouse *lights are off*
I have swap my ram around, still same problem, ive used 1 stick and rotated them..
I unplug everything and plugged it back in, yes i can build a pc my self with my eyes closed, my hands are really tied though so i tried to take a shortcut and just bought it from ipower *gulp*
Anyone have any information/tips for me before I do send this thing back to ipower ???
***UPDATE***
Motherboard throws up a white led indicator that says VGA in the manual, gpu seems fine though
asus 1070 8gig
Problem with pc
***UPDATE***
