Brand New to OC with AMD FX 8120
pinoyremix
My Current PC Setup:
Cpu: AMD 8120
MB: MSI 990 FXA GD 80
Cooler: CM Hyper 212 Evo
Ram: Corsair Vengence LP 2 x 4 GB 1600 mhz
GPU: MSI 560TI TwinFrozer II OC
PSU: Corsair AX 650
Case: Antec 302 + 3 additional fans
I am new to OC and just wanted to check to see if my settings are correct. I am looking for a safe and modest OC. I have been running prime 95 for 30 min.
Get your HWMonitor expanded like this below. It has more information that way. Otherwise if you are where you want to be and are two hours of Prime 95 blend stable, then you should be okay.
attachment.php
Cpu: AMD 8120
PSU: Corsair AX 650
Very safe and modest - I'm not much higher clocked then you and your temps are well below danger levels.
