- May 9, 2011
- Alberta, Canada
Hey all,
So I've been tossing the idea around in my noggin for a while to watercool my PS3. I have a first gen (fat) PS3 (originally 60GB, upgraded to 500GB) that screams like a banshee when I game or watch movies for any significant length of time. I figured since watercooling can greatly decrease the noise of a computer, why not do the same for my PS3?
So, I got to researching and put together a parts list. Then I pulled the trigger and bought all of the parts:
1 MCR320 Drive rev 3 (360 rad, MCP35X pump and built in res)
1 Alphacool PS3 water block
1/2" ID 3/4" OD Primochill UV blue tubing
1/2" ID 3/4" OD Koolance barbs with spring clamps
3 Yate Loon low speed 120mm LED blue fans
Various braces, extensions and rubber feet for a makeshift rad stand
1 AC 120V to DC 12V 5A (molex) power adapter (rather than a full PSU)
1 Belkin Conserve power bar
The power bar allows one device (Master) to control up to 5 other devices simply by turning on and off. When the device is in standby, power is shut off to the 5 Master Controlled devices automatically, and when it turns on, power is restored. This will allow me to turn on the pump and fans simply by powering on my PS3 and will hopefully avoid me having to manually turn the watercooling on and off. I can't take credit for this idea as it was posted in my parts thread by givmedew (thanks btw!).
The molex power adapter is rated for running up to 12 low speed fans simultaneously (5A) at 12V. Since each of the Yate Loons will draw 0.3A and the pump draws 1.5A, I figured this will be plenty for my needs and will eliminate the sound of a PSU fan.
So, onto the pics:
I'll be back with more hopefully soon
So, onto the pics:
