I have been planning a water cooling build for months. I owe a lot of thanks to the members here for providing some helpful guidance. I tried not to be too much of a pest as I was trying to figure out where I wanted to go with water cooling.
I have actually had all of my parts for a couple of weeks. But a crazy busy work schedule has kept me from it. This is the first weekend I have had off in two months, so I will be starting my build today.
This is a transplant build. The system was put together two months ago in a Thermaltake Armor+ case using the following components:
EVGA X58 Classified 3 Motherboard
EVGA Superclocked GTX570 in Triple SLI
Intel Core i7 970 6-Core CPU
24GB of G.SKILL DDR3 1600 memory
Crucial 128GB SATA III Solid State Drive
Two 2TB Western Digital Caviar Black 6.0Gb/s SATA Hard Drives
Lite On Blu-Ray Burner
Corsair AX1200 Power Supply
Here's a photo of that build:
I'm quite satisfied with the performance of this rig and my only complaint is that the highest OC I can get is 4.0GHz before temps become a concern. So my hope is that with water cooling I'll be able to get that up to about 4.6GHz. I've pushed the Cooler Master V10 as far as it can go with this processor.
I went through several iterations when it came to choosing a case. The Thermaltake Armor+ is a nice enough case. The only thing I really don't like about it is the plastic shroud/bezel on top of the case. Other than that, it is well built, sturdy, and has plenty of room inside. I thought about keeping it and simply re-building the system with water cooling. If I was going to do a CPU only loop then I might have done just that.
But then I saw the Silverstone TJ07 case and throught it was a thing of beauty. The bottom section was ideal for water cooling. And so I ordered one. When it arrived and I opened it up I was concerned. The case was really nice, but it seemed a little cramped to me. At the time I was still thinking about just a CPU loop and felt that putting a single 360 or 480 rad in the Silverstone was fine. But then I started to think seriously about water cooling the GPUs, and was worried that two rads might make things a bit tight. I wanted to avoid modding the case. For one, I really don't have those skills. Secondly, I have seen plenty of pictures of builds that are very cramped and was determined to avoid that. Even if I had to spend a lot more on a case with enough room to grow. So I was considering between the Mountain Mods Ascension and Danger Den Double Wide cases. In the middle of my case deliberations someone here suggested that I consider a Caselabs case. So I checked it out and ended up buying one.
It is massive. So massive in fact, that I will have to move my office desk about 5" to the left to make room for it. But I think it will be worth it. There is plenty of room in the TH10. The case is divided into two sides, a component side and a power supply side. It can take up to five 480 rads. I will be mounting my two 480s in the two mounts at the top. Options for this case are plentiful. I added a water cooling pump mounting tray and power supply support bracket, each for an additional $10. The case was a little over $600 delivered. It is modular, has a removable motherboard tray with CPU socket cut out, and has pre-cut cable/tubing routing holes with rubber grommets. It's very well made and is available in matte black and gloss white. I like the matte black finish though I wish Caselabs would consider offering a gloss black finish.
Here's a pic of my water cooling components, sitting on a bed in a spare bedroom that I am in the process of coverting into a coffee bar.
CPU Loop
Swiftech MCR420-QP Radiator
Swiftech MCP655 Pump
XSPC Acrylic Tank Reservior for Laing D5 Pump
Koolance CPU 370 Water Block
PrimoFlex Pro LRT Blue UV Tubing 3/8" ID 5/8" OD
Bitspower Compression and Rotary Compression Fittings
GPU Loop
Three Koolance VID-NX580 Water Blocks
PrimoFlex Pro LRT Red UV Tubing 3/8" ID 5/8" OD
Danger Den SLI connectors
Both loops will use distilled water, PT nuke, and have a kill coil in them.
I went with Cooler Master SickleFlow 120mm 2000RPM fans. This was another thing I labored over. I really wanted Scythe Gentle Typhoon 1850RPM fans but no one seemed to have them in stock. So then I thought about the Enermax Magma fans. They were available and I came very close to buying them...but I had to ask myself if I was really prepared to spend $200 on fans. I decided to look for a lower cost alternative. I was going to buy Yate Loons. They are inexpensive and seem to be highly regarded. But then I saw the Cooler Master fans for $8.95 each and felt their airflow and noise ratings were what I was after.
While this build is in progress I will be using my IBM Thinkpad laptop. I can live without my main rig for three or four days. I'm hoping to get the assembly work done over the weekend and have both loops filled, leak tested, and running by Tuesday. I'd like to have my system back in production by mid week. I think that's a reasonable expectation.
I have read all of the materials I could find on building and watched enough videos on Youtube so I think I have a good handle on what I need to do. I have laid out a plan and all I need to do is take my time and execute it.
It will probably be a few days before I post back with pictures and comments.
CPU Loop
GPU Loop
