- Apr 11, 2010
- London, UK
Ok guys so some of my parts have arrived at work so i though i would start my build log now! XD
My rig is in my sig!
So I'm going to start off with a CPU loop. And to cut down on costs ( as it is my first WC build ) i decided to go with the XSPC Rasa 750 RS360 WaterCooling Kit. Which consists of:-
1 x XSPC Rasa Black CPU Waterblock
1 x XSPC RS360 Radiator
1 x CPU Backplate for 1366, 1156, 1155, 775
3 x 120mm Fan
1 x XSPC X20 750 Pump & Reservoir combo
2 x 7/16" Clear Tubing
6 x 1/2" Barb Fittings ( i have got 4XEK compression fittings for my block and rad cos i think barbs are a bit ugly. )
1 x 5mm Blue LED
1 x Velcro Mounting Pad for Pump
6 x Hose Clips
1 x 80 - 120mm Radiator Mounting Kit
1 x Thermal Paste
1 x CPU Mounting Kit
3 x 120mm Fan Grill
I have also got 5L of dionised water and a 10ML bottle of Mayhem Biocide. Im going to stick with clear water without any colouring for now. I'll probs swap my tubing for some primochill blue transparent stuff, If i can find any! grrrr.
I will also be adding my GPu into the loop when i upgrade it!
Anyhu
My EK fittings and biocide arrived at work! Excitement is mounting!
ok so kit has arrived on my lunchbreak! ( couldnt take it all out and show it properly, but will replace with a better image when i get it home)
Hope you all enjoy the build!
3 x 120mm Fan
1 x 5mm Blue LED
6 x Hose Clips
1 x Thermal Paste
3 x 120mm Fan Grill
Anyhu
