- Apr 16, 2009
- Prince George, B.C.
Well here is another build log. The case will be a black and white theme with shrouds added to improve the cooling layout of the case.
pic before build.
CASE:
AZZA Genesis 9000B
Old Hardware:
Sabertooth z77, 2700K, OCZ Agility4, EK Supreme HF, 2 swiftech 655 pumps, 2 swiftech mcr320QP, sunbeam fan controller
New Hardware:
xfx double D 7970, xspc 7970 fullcover block, bitspower dual D5 pump top (acrylic), Bitspower dual d5 mod top resivoir.
Now the problem with the 7970, when i ordered the part i did not know that there was a new revision that caused the block not to be compatable any longer. however so long as the core and mem layout is still correct then i can modify the rest to fit, I'm thinking its just a matter of shaving off a section a bit to fit over a component. I will document this in the build log.
The Plan:
Here is the plan in a nutshell is I'm going to remove slats in the top case fascia and replace them with mesh to improve airflow. in the bottom of the case im going to add shrouds made of white translucent plexi and the pumps will rest in 2 holes in the shroud with the bitspower modtop above the plexi. I will paint the thermal armour on the sabertooth white.
the led lights in the xspc waterblock, the ek supreme hf, and the bitspower modtop will be blue.
pic before build.
CASE:
AZZA Genesis 9000B
Old Hardware:
New Hardware:
The Plan:
