So the price is significantly different between these two but to me they seem to be the same? Is there a big difference in the two or would the cheaper one be okay to go with??
Put the specs side by side, you'll see a lot of differences. M.2 support, 2 x PCI-E 3.0 Ports, Better audio, just to name a few of the options the more expensive board has.
yeah when you said put the specs side by side I noticed the differences. Another question, would the change in graphics/audio etc., be THAT significant where the extra $100 would be worth it? Or would the cheaper one be good enough to run everything smooth still.
