- Thread Starter
- #21
I didnt... With my mobo, support for 1333 FSB didn't come out of the box, so the first thing I had to do was flash the BIOS. Scariest thing ever! But I dont see a problem with doing Windows first thing.
Thanks.
im not putting it on top because i am putting watercooling in the top part of my case....
i could turn it on but what would be the point? i would just have to shut it down. It would be nice to see if it was working though..
QUESTION: when i first turn on my pc, should i put the xp cd in first thing and load the OS?
Probably just have to turn them around in there hook up thingy. The polarity needs to be right, no biggie though.
like this:
Thanks a lot!!!!! i will fix that.
Not sure why my other fans aren't working... :-(
i will post a pic of the connector. But i am pretty sure that it should work...
Check th emolex connections (The connectors on the power supply cables) that are feeding your fans, and the molex connectors on the poer leads to your fans. Often those connectors for fans are done pretty badly, and they can and will short out on you sometimes. Play around with them till they work.
my fans are connected to my mobo not my power supply. is that my problem ? i have 4 fans connected together with molex.
If your fans are standard 4 pin connectors, plug them into a power supply molex. You can piggy-back them, they dont use much.
good idea i will have to try that. also where can i find a 4pin atx mobo extension. i have to stretch it hard and it barely fits cause it has to go over the gfx card. I want to reoute it behind the mobo plate.
We have the same power supply and there is a 2 pin molex extension plus another 4 pin molex connection directly to the power supply. Try them unless they are all being used.
