I have 2 damaged MB's that I would like to see run again if at all possible. I am pretty sure one is shot but the other I am not sure on. The 1st one is an ASUS A7V333 with Raid. I had a screw driver slip off the heat sink connector which broke the tab that the heat sink connects on ( i know I can get a 3 hole connection) and the screw driver hit what I am guessing are little resistors between the 2 coils by the serial ports. Is this fixable? I never received any useable response from ASUS tech support as I am guessing they didn't understand what I was saying via email. Any suggestions? The second one is a DFI AD73 Pro that I bought after killing the ASUS before I got the deal on the Dragon. The DFI has nothing physically wrong with it, it received a bad flash (I can't remember what I did wrong there) and won't power up and the bios chip isn't replaceable like the Dragon's is. Any suggestions for this one? I emailed DFI and nevre received a response at all from them. Thanks a lot for any help you may have.
Okay I just remembered what happened to the DFI, the FSB jumper was accidently "removed" with the PC off but the PSU still on....
