Hi all, I cannot seem to get the E8400 to overclock stable at 3.6Ghz..no matter how much voltage I apply to the CPU. Currently I have it stable at 3.546Ghz at around 1.26 Vcore and multiplier at 9. If I bump it up to 3.6 and apply more voltage, the pc will freeze up before loading to desktop, so I backed off the frequency and voltage. I have not tried adjusting the multiplier at all, but I didn't see any advantage to this. ALso, I had applied 1.4 Vcore while at 3.6, but no-go on successful boot.
Ram timings are unlinked 4-4-4-12 2T @ 2.1V. NB is at 1.35V and all other voltages auto.
Mobo is ASUS P5N32-E SLI, 680i chipset with latest BIOS 1403. I had a similar problem with the E6750 with this board. I could not get anything stable beyond 3.0Ghz at max Vcore 1.5.
At any rate, just curious as to where I may be going wrong with this. Maybe the mobo is causing the limitation? Maybe the Corsair ram I have isn't holding up to the OC challenge?
Thanks!
Thanks!
