- Jul 29, 2013
- England, Sheffield.
- Thread Starter
- #21
Dom before you attempt to do any kind of unlocking/overclocking you need to address the cooling issue.
What case do you have? Judging by the photos it looks like a Xigmatek ASGARD?!?! If it is then it's 7.28" wide so you'll have some restrictions on what cooler you can fit.
The heatsink you have on there looks like a COOLER MASTER DK9, it should be cooling the chip a bit better then it is. What are your ambient temps and when was the last time the heatsink was cleaned and or removed and had the TIM replaced?
Yes It is an Xigmatek ASGARD, I have never in my life cleaned the heatsink or had the TIM (what is a tim? the thermal paste?) replaced. "What are your ambient temps" Where do I find this mate?
No still no pics the site is blocked by my employer. As for the pink cooler Not the best IMHO. You'll want something that fits a 120mm fan on it like this Your biggest concern is the height. The cooler 159mm high so you need that much room between your CPU and case door for it to fit. If you're looking around look for one that fits an AM3 socket. You can put pink fans on any cooler if you really want to.
Ah I see, there is loads of room between the door and fan length wise but the power supply stops it from there being much room height wise.
