Here's a pic of my custom build: http://www.overclockers.com/forums/showpost.php?p=6650230&postcount=2377
I have two case fans, one currently in use as an outflow (the back of the case in the above link). I removed the second one because I wasn't sure if I'd need it- I wasn't using the system for gaming, but I noticed the computer powered off when I'd play video for a minute or more. This hadn't happened before with video and I think it may be because I removed one of the two case fans. So the question is, if I put an in-flow fan on the side of the case facing the low-profile video card (ATI 4350 HD)), but the airflow doesn't seem to curve upwards towards the out-flow fan because the video card blocks a bit of air ( I had it facing the heatsink, but I could raise it so it's above the card, which may facilitate flow), should I move the side case fan to the front of the case (the front slot is kinda hard to attach the case fan- it's somewhat inaccessible). My alternative option is to use the onboard video (ATI 4200 HD), which would have more open airflow from the side to the back of the case.
Biostar 785 GE 128M AM2/AM2+/AM3
Sempron x2 2300 2.2Ghz
8GB Corsair DDR2 800Mhz 5-5-5-18 (4GB installed)
OCZ Onyx 32Gb SSD
MSI 4350 512MB Low Profile
Seasonic S12 330W 80+ Bronze
2x MassCool 80mm FD08025B1M3/4 RT
Cooler Master DK9-7E52A-0L-GP
Linux Mint Debian Edition 32-bit
OCZ Onyx 32Gb SSD
