- Aug 17, 2002
Cheezboy said:this will give you a good idea what a delta screamer sounds like
http://www.sidewindercomputers.com/lib/sidewindercomputers/01Delta80x38mmFFB0812EHE.m3u EDIT OOPS I FIXED THE LINK
here is a 80mm Stealth, Adda, and Tornado compared. (bad audio though on tornado just a bunch of rushing air it does seem less high pitched though)
http://www.modthebox.com/reviews/vantec/tornado/tornado.wmv
Cheezboy said:ya its ONLY 59 dBA !!!!!!
lol!Well, you must be hardcore. OK, how about crazy? You must be if you're looking at this fan. We've had several requests for these, so here they are. 190 cubic feet of wholesome goodness. It sure "feels" like it too. The FFB1212EHE has "Server Use Only" written all over it. If you do decide to strap this jet engine in a desktop PC, be sure to apply a second sheet of Dynomat to save your ears.
Tygur said:If sound doesn't matter at all, then you would typically go for the loudest fan, because that's the one that will blow the most air. The 80mm Tornado blows at 84cfm
Army_Of_1 said:120MM Deltas are 130CFM, that's the highest one anyway.
