- Jul 18, 2012
My Stock Corsair 2 200mm and 120mm fans are really getting louder and its not as efficient as before. Considering where I'm from and with summer fast approaching, its really going to get brutal as far as temps are concerned. I would really like some recommendations for a quiet setup but with some good cooling.
I was also thinking of using 2 120mm fans on the front, 1 200mm fan at the top panel and a 120mm exhaust on the top back panel. Or is the stock configuration good enough with new fans?
I like the NZXT FS 200RB 200mm Silent Fan and the Corsair Air Series SP 120mm.
Current temps
cpu: 45C idle
62C load
Gpu: 65 idle
90c load
Current temps
cpu: 45C idle
62C load
Gpu: 65 idle
90c load
