I'd put emphasis on the GPU. This Nvidia 970 will do every you can think of better than any other chip in this price range.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125806
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113399&ignorebbr=1
MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128565&ignorebbr=1
While I didn't add it up, this might even hit your price point.
NOTE: This is meant as a starting point and a start of your search.
Except dx12, and considering the op doesnt upgrade often, he may want to go with team red for more future proofing and room for higher resolutions down the roadI'd put emphasis on the GPU. This Nvidia 970 will do every you can think of better than any other chip in this price range.
If you have an i5 now, you might be happy with just a GPU upgrade. In that case, an Nvidia 980 would rock your world.
A GPU that is in the same price point at the Nvidia 970 would be the R9-380 I think and would have DX12. I don't know when DX12 will be a "thing" but it isn't yet. My experience with getting GPUs for a DX level that isn't mainstream yet is abysmal. I personally will not buy a GPU for a DX version that is not yet mainstream.
In terms of recommending a full ATX MB, I don't have a recommendation. Most will be fine especially if you don't OC. If you do OC, then your budget is toast. I've had great luck with MSI MB but horrific results with MSI GPUs.
So you pick probably if not the worst 970 ever made and claim there is nothing else in the price point?A GPU that is in the same price point at the Nvidia 970 would be the R9-380 I think and would have DX12. I don't know when DX12 will be a "thing" but it isn't yet. My experience with getting GPUs for a DX level that isn't mainstream yet is abysmal. I personally will not buy a GPU for a DX version that is not yet mainstream.
Good information.So you pick probably if not the worst 970 ever made and claim there is nothing else in the price point?
that 970 was one of those mini 970's with a single 6 pin connector on it, blower style complete with noise and coil whine
$500Tough crowd....
Anyway, what is your budget for the parts you want to upgrade OP?
the i5 i have it might be an i7 i cant remember but either way its 5 years old now and even with my 6950 it can just barely run fallout 4 on the lowest settings possible
It's not a big deal. It's not what you said but the delivery of that information.not looking to start arguments or anything, just voicing my opinions
maybe i'm missing something because this looks like a mini card to
I lived with a blower cooler for almost 8 years, it was not pleasant
I don't know if the op still has the antec 900 which has decent airflow and can vent out the top
+1 (and something I need to work on more times than not too, LOL!It's not what you said but the delivery of that information.
$500 really isn't going to get you much. You can see the GPUs we are recommending are already $330 leaving you $170 for CPU and mobo...I would really look to increase your budget a couple hundo so you can get maybe a GTX 980 or a R9 390 as well as a decent CPU and mobo. If you upgrade that infrequently, you will be thanking us two years down the road.
Oy... UPDATE YOUR SIG OP!!!!!!!!!!!!!!!!
Hell if he has an i5, that will still be good and he can upgrade to an i7 in a year or two if needed!!!I'm going to jump back and say that if indeed the OP has a core i7, just get a good GPU and call it done.
+1this, I originally thought those were his specs
now you can get a gtx 980 or r9 nano
