Chrome History Deletion
Berne
Hi,
Using a Chromebook Slate, unable to clear browsing history , after correct command initiated, history page shows looping circle with no deletion of any history ? All free apps are too tech, is there a simple work around or a pay for app that will take care of this on top of the VPN being active ?
Regards,
Berne
Are you trying to reset it inside of chrome?
Settings -> privacy and security -> clear browsing data?
(Referencing the settings on the chrome browser on my android phone I have to imagine it's the same or similar)
Issue resolved , reinstall solved all, just make sure to use cloudflare as pre server , a real winner.
Berne
