Let me try and help you guys out a little here with a little known paint secret.
You need to use a paint called "Alclad2"
Here is my buddies website that explains what you need to know about Alclad2:
http://home.earthlink.net/~rayra/alclad2x/index.htm
The paint is only as good as the surface prep.
The surface needs to be clean and have a gloss black paint applied to it.
You cant touch the black paint or the fingerprints will show on the Alclad2 coating.
The finish is very very very durable.
The chrome is just about as real as you will get short of being real chrome.
The polished aluminum does indeed look like polished aluminum.
I build original and replica props for film/tv and private collectors. Alclad2 is the best way to get a metalic finish on just about anything. The paint has been used in the film/tv industry for some years now.
If you are going to coat something such as a computer case, you will have to sand the surface smooth as the groves in the typical computer case's surface will distort the Alclad2 finish.
Best of luck.
Best of luck.
