sigh,
around and around we go.
Again,
this is a thread about chrome paint not about chrome. If you want to start a debate thread "Chrome vs. Alclad2 paint" then so be it.
as posted by the thread topics starter in the his second post:
"I am not trying to make it look EXACTLY like real chrome... as I know there is no duplicating that with a spray can. Just want a chromy effect. So is it doable? Thanks"
vonkaar,
you seem to be taking this rather personally and then retort by talking down about a paint that is a quality product while knocking my own work with it and that I do take personally.
Alclad2 chrome is a paint.
It will give a reflective mirror'y surface to most any smooth surface short of said surface being a couch or the carpet below your feet or the neighbors cat...
Its all about the prep work, again, as is any painting work.
vonkaar, no offense but if you have seen a shop that gets paid to use Alclad2 chrome and cant get a reflective surface with it, that shop shouldn't be using it or the shop needs someone who knows a little more about the prep work or maybe the correct surface paint hasn't been applied. I use regular old Krylon high gloss black spray paint from the Home Depot near my house as a surface coat.
"Alclad2 is as close to chrome as you will get short of being actual chrome"
I also said that in my second post which also baffles me as to why we are still having this discussion.
"I have never said that Alclad looks like crap"
But that's what you have been insinuating even after you have seen my work with Alclad2 which, again, is why I take this a little personally.
If you did not intend to knock my work in the pictures above, then I apologize for taking offense to your comments.
I have posted what info I can to help those in search of a chrome paint that is as close to real chrome as possible that they can get cheaply and do at home.
If someone wants real chrome, spend the money and send the part to a shop.
Again,
vonkaar,
