- Thread Starter
- #41
Nice seeing u post here Musicfan. In fact many of those threads you posted in from years ago were data where I collected data. I recognized your unique postings as they are rarely less than 200 words per reply.
I do think pH is a strong contributor to the tubes clouding, and CuSO4.. from
Cu0H (a weak alkaine)
H2SO4 (a strong acid)
makes CuSO4 inheritly acidic when in aquaeous form. I think a lot of people ended up using more than 'recommended', when 1 drop, did 3. (read it from many many posts), and as a result, they run a tube of acidic water.. (which is a TERRIBLE thing .. as given time = corrision of your CPU block.)
however, it is also true that tubings from years ago, seems to be of much better quality. I am not sure if the source of tubing of Primochill and some brand are the same, (wont be surprised if so), but if they are, then I think the recent brands became much more vulnerable to Acidic solutions, and clouds up MUCH faster...
hence, I believe the result will be...
Poor brand + too much CuS04
regardless.. on my next loop. I am silver only.
