- Mar 22, 2008
- Greece
My hands were itching today so I took apart my main rig and cleaned up everything (dusted fans etc.).
I also decided to try placing the PSU on the bottom.
I thought that since hot air travels upwards, 2 80mm fans on the top where the PSU originally was would help more than if they were on the bottom.
Also cable management appeared to be easier with the PSU on the bottom.
Placing the PSU on the bottom also lowered the center of gravity, so the case is harder to tip over now.
I have a question though: my PSU is an OCZ ModXstream with a 12" fan on the bottom.
Initially I thought about placing it with the fan facing upwards, but I was afraid of any screws falling into it.
I know that you 're supposed to install it with the exhaust fan facing downwards, but to tell you the truth the Stacker's grill on the bottom doesn't look like its good for airflow...
I unscrewed it and screwed it back on the outside of the case, giving the exhaust fan some more space to move air.
To those of you with Stackers, where do you place the PSU?
