- Sep 13, 2010
- not sure
I started liquid cooling back in the early 90's when we used copper pipe caps brazed to copper plate for our block, and standard brass barb fittings from Lowes to connect everything (and we liked it, dammit!).
Anyway, I have a real Swiftech block now and find myself graduating from the barbed fittings to the compression type for soft tube. My big question is, when tightening (or loosening for that matter) a compression fitting, how do you get a good grip on the narrower side? Both the thick ring and narrow ring are normally knurled, but I can seldom get a good grip on the narrow ring. If the fitting has a pretty anodized finish and I try to use some needle nose plyers I'm sure I'm going to ruin the finish.
What I need are some soft-jaw very narrow channel lock plyers. I've looked everywhere online for such a thing and can't find it... unless there's some trick I'm missing. How do you experts do it?
