- Nov 13, 2014
- Hamburg,Germany
Hello guys , I am new to this Forum and I would like some help for my next computer build.
Firstly I would like to tell you that my budget is around 500 Euro. Ok it could be also 550 or 600 euro if we can change something on it that its really better than other options .
At this point I would like to say that I like playing games on my PC and it would be nice if with that budget, I can have a PC that I can play games in high quality graphics.
I made myself a built and I want you to have a look at it . I want to be sure that the build is correct and all parts are working together well.
so here's the built:
CPU: AMD FX 6300 Hexa-Core Prozessor (3,5GHz, Socket AM3+ 14MB Cache, 95 Watt)
Motherboard: Asrock 980 DE3/U3S3 Mainboard Sockel AM3+ (ATX, AMD RX881/760G/SB710, 2x SATA III, 4x DDR3-Speicher, 4x USB 3.0)
RAM: Kingston KHX1600C9D3K2/8G Arbeitsspeicher 8GB (1600 MHz, 240-polig, 2x 4GB) DDR3-RAM Kit2
PSU: Sharkoon WPM600 V2 PC-Netzteil (600 Watt, ATX, Kabelmanagement,80% effieciency)
HDD: Western Digital WD10EZEX Blue 1TB interne Festplatte (8,9 cm (3,5 Zoll), SATA 6Gb/s, 64 MB Cache)
GPU: Asus GeForce GTX 670 Grafikkarte (PCI-e 3.0, 2GB DDR5, DisplayPort, Direct CU II, HDMI, 2x DVI)
I hope I didnt forget something. I have also a question . the graphic card says is PCIE 3.0 , is this motherboard ok for this graphic card?
and also at coolermaster's website there is a PSU calculator in which you add all the compnents of your PC and it says how many Watts PSU is needed in order to play properly . and with this built it showed me that I need 380W PSU, which for me I think is pretty low .
feel free to suggest me your own build with this budget. Actually I would really appreciate it .
thansk in advance ,
Aggelos K.
thansk in advance ,
Aggelos K.
