Regarding the computer in my signature, it has worked without issue for months then as of a few days ago, the entire computer randomly shuts off and restarts. When this happens it normally gets stuck in a restart loop by which it will shut off and restart every few seconds at random times. I cut the computer down to the minimal: 1 stick of ram, 1 HDD, onboard video, all stock speeds and BIOS settings, and nothing else. I found that greatly reduced the frequency in which the computer restarts, but it does not eliminate the problem. So I bought a new PSU. The new PSU did not fix the problem either.
Now I am finding that the orientation and number of RAM sticks seems to have an effect. Sometimes I can get the computer to run fine if I am only using one stick of RAM, but when I put two in (single or dual channel), the computer cant even get past POST without restarting sometimes. So then I switch back to one stick of RAM and sometimes the problem still occurs, other times the computer will boot without problem. The orientation of the RAM and number of RAM sticks seems to affect the problem, but aside from that I cannot identify a pattern. I know it has nothing to do with settings or software because the crash has happened while I am in the BIOS, and I have reset all the BIOS settings to stock.
So, motherboard or RAM? I am guessing it's the mobo. Has anyone heard of this issue with the AsRock3 mobo in my signature?
