- Dec 1, 2007
- Near Toronto Canada
- Thread Starter
- #21
That wireless card uses a Qualcomm chipset, the leader in wireless. As with all wireless hardware, you might need to use aftermarket high gain antennas for best results. Position the two antennas about 90 degrees from each other, same goes for the AP antennas. (If the AP has 3 antennas, put the outer two about 90-120 degrees apart with the middle one bisecting the angle.)
So I should position the antennas in a V on the card and in a V on the router with the middle antenna as an I is what you're saying? (My router has 3 antennas)
