Since I dont currently have the spare cash for a new build, I will be overclocking my e7200 soon in anticipation of the SWTOR release. I plan on buying a Cool Master Hyper 212 EVO and some Arctic Silver 5 to cool it.
This is the case I have (http://www.newegg.com/Product/Product.aspx?Item=N82E16811119106) and I am not exactly sure if the 212 EVO will fit. I am pretty sure the height will be fine as I have removed the funnel but how do I tell if the power supply will be in the way? I know the dimensions of the heatsink but it is still tough to judge.
I made a post a while back on a similar topic, and it was suggested that I replace the exhaust vent and the side vent that has a fan to increase air flow, which I plan to do. On this same topic would it be beneficial to cut a large hole in the side of the case as well and in its place put a screen? I open and get dust out of my computer regularly so I was thinking that even if this did allow a bit more dust to get in, it wouldnt be that big of a deal because of this and that the increased benefit of more ventilation would make it worth while.
