I am planning my first custom watercooled build. Most of the components are in the "to-be-decided" phase but the items below i am fairly confident about:
Case: Caselabs TH10A
Pumps: Swiftech MCP 655-PWM
Radiators: 4 x Alphacool NexXxoS UT60 480 push/pull (considered the Black Ice Nemesis GTX but the height of the UT60 matches the factory holes between the two sides of the TH10A better)
CPU: Intel 5960x
GPU: Waiting for next generation Geforce 8xx. Two or three SLI, depending on what Star Citizen requires
Triple monitors with 1920 x 1080
Questions:
Should I watercool the motherboard? I have really limited knowledge about PC's but from what I have read so far the VRM's are included in the CPU on the Haswell editions and therefore cooling the motherboard is less important. In my current build though (which is quite old...), overclocking the motherboard improved my benchmarks a lot. If there is a small chance my overclocking potential will be hampered by not cooling the motherboard I will. But if its 99% for looks and show I will keep it simple.
Single or dual loop? Two or four pumps? For gaming the CPU is probably not going to run too hot. When I am runnning CPu intesive software the GPU's will be idle. I don't see any real world application where both CPU and GPU are 100% stressed at the same time. Therefore I am inclined to use single loop. There is quite a bit of radioator surface, and to me it seems my GPU's would benefit from the extra cooling. With limited load the CPU should be able to keep fair temperature even with a slightly higher water temperature than they would have seen on a separate loop. This is not according to most recommandations I have read though so would like your comments. What do you think?
CPU: Intel 5960x
Questions:
